Implementing ArcGIS Blog
Other Boards in This Place
Latest Activity
(182 Posts)
MichaelHatcher
New Contributor III
In this entry, we will be looking at what a deployment looks like from the infrastructure as code (IaC) perspective with Terraform as well as the configuration management side with PowerShell DSC (Desired State Configuration). Both play important roles in automating ArcGIS Enterprise deployments, so let's jump in.
This deployment will follow a single machine model as described in the ArcGIS Enterprise documentation. It will consist of the following.
  • Portal for ArcGIS 10.7.1
  • ArcGIS Server 10.7.1 (Set as Hosting Server)
    • Services Directory is disabled
  • ArcGIS Data Store 10.7.1 (Relational Storage)
  • Two (2) Web Adaptors within IIS
    • Portal context: portal
    • Server context: hosted
    • Self-Signed certificate matching the public DNS
Additional Configurations
  • WebGISDR is configured to perform weekly full backups that are stored within Azure Blob Storage via Task Scheduler
  • Virtual machine is configured for nightly backups to an Azure Recovery Services Vault
  • RDP (3389) access is restricted via Network Security Group to the public IP of the box in which Terraform is ran from.
  • Internet access (80, 443) is configured for ArcGIS Enterprise via Network Security Group
  • Azure Anti-malware is configured for the virtual machine
The complete code and configurations can be found attached below. You will need to provide your own ArcGIS Enterprise licenses however.
Note:   This is post two (2) in a series on engineering with ArcGIS.
Infrastructure Deployment
If you are not already familiar with Terraform and how it can be used to efficiently handle the lifecycle of your infrastructure, I would recommend taking the time to read through the first entry in this series which can be found here. The Terraform code in that first entry will be used as the basis for the work that will be done in this posting.
As discussed in the first entry, Terraform is a tool designed to help manage the lifecycle of your infrastructure. Instead of rehashing the benefits of Terraform this time however, we will jump straight into the code and review what is being done. As mentioned above, the template from the first entry in this series is used again here with additional code added to perform specific actions needed for configuring ArcGIS Enterprise. Let's take a look at those additions.
These additions handle the creation of two blob containers that will be used for uploading deployment resources ("artifacts") and a empty container ("webgisdr") that will be used when configuring webgisdr backups along with the uploading of the license files, the PowerShell DSC archive and lastly, the web adaptor installer.
resource "azurerm_storage_container" "artifacts" {
  name                  = "${var.deployInfo["projectName"]}${var.deployInfo["environment"]}-deployment"
  resource_group_name   = "${azurerm_resource_group.rg.name}"
  storage_account_name  = "${azurerm_storage_account.storage.name}"
  container_access_type = "private"
resource "azurerm_storage_container" "webgisdr" {
  name                  = "webgisdr"
resource "azurerm_storage_blob" "serverLicense" {
  name                   = "${var.deployInfo["serverLicenseFileName"]}"
  storage_container_name = "${azurerm_storage_container.artifacts.name}"
  type                   = "block"
  source                 = "./${var.deployInfo["serverLicenseFileName"]}"
resource "azurerm_storage_blob" "portalLicense" {
  name                   = "${var.deployInfo["portalLicenseFileName"]}"
  type                   = "block"
  source                 = "./${var.deployInfo["portalLicenseFileName"]}"
resource "azurerm_storage_blob" "dscResources" {
  name                   = "dsc.zip"
  type                   = "block"
  source                 = "./dsc.zip"
resource "azurerm_storage_blob" "webAdaptorInstaller" {
  name                   = "${var.deployInfo["marketplaceImageVersion"]}-iiswebadaptor.exe"
  type                   = "block"
  source                 = "./${var.deployInfo["marketplaceImageVersion"]}-iiswebadaptor.exe"
This addition handles the generation of a short-lived SAS token from the storage account that is then used during the configuration management portion to actually grab the needed files from storage securely. In this situation, we could simplify the deployment by marking our containers as public and not requiring a token but that is not recommended.
data "azurerm_storage_account_sas" "token" {
  connection_string = "${azurerm_storage_account.storage.primary_connection_string}"
  https_only        = true
  start             = "${timestamp()}"
  expiry            = "${timeadd(timestamp(), "5h")}"
  resource_types {
    service   = false
    container = false
    object    = true
  services {
    blob  = true
    queue = false
    table = false
    file  = false
  permissions {
    read    = true
    write   = true
    delete  = true
    list    = true
    add     = true
    create  = true
    update  = true
    process = true
The final change is the addition of an extension to the virtual machine that will handle the configuration management task using PowerShell DSC. Instead of reviewing this in-depth here, just know that the data that is getting passed under the settings and protected_settings json will be passed to PowerShell DSC as parameters for use as needed by the configuration file.
resource "azurerm_virtual_machine_extension" "arcgisEnterprise-dsc" {
  name                       = "dsc"
  location                   = "${azurerm_resource_group.rg.location}"
  virtual_machine_name       = "${element(azurerm_virtual_machine.arcgisEnterprise.*.name, count.index)}"
  publisher                  = "Microsoft.Powershell"
  type                       = "DSC"
  type_handler_version       = "2.9"
  auto_upgrade_minor_version = true
  count                      = "${var.arcgisEnterpriseSpecs["count"]}"
  settings = <<SETTINGS
		"configuration": {
          "url": "${azurerm_storage_blob.dscResources.url}${data.azurerm_storage_account_sas.token.sas}",
          "function": "enterprise",
		  "script": "enterprise.ps1"
		"configurationArguments": {
          "webAdaptorUrl": "${azurerm_storage_blob.webAdaptorInstaller.url}${data.azurerm_storage_account_sas.token.sas}",
          "serverLicenseUrl": "${azurerm_storage_blob.serverLicense.url}${data.azurerm_storage_account_sas.token.sas}",
          "portalLicenseUrl": "${azurerm_storage_blob.portalLicense.url}${data.azurerm_storage_account_sas.token.sas}",
          "externalDNS": "${azurerm_public_ip.arcgisEnterprise.fqdn}",
		  "arcgisVersion" : "${var.deployInfo["marketplaceImageVersion"]}",
          "BlobStorageAccountName": "${azurerm_storage_account.storage.name}",
          "BlobContainerName": "${azurerm_storage_container.webgisdr.name}",
          "BlobStorageKey": "${azurerm_storage_account.storage.primary_access_key}"
	SETTINGS
  protected_settings = <<PROTECTED_SETTINGS
          "serviceAccountCredential": {
            "username": "${var.deployInfo["serviceAccountUsername"]}",
            "password": "${var.deployInfo["serviceAccountPassword"]}"
		"arcgisAdminCredential": {
			"username": "${var.deployInfo["arcgisAdminUsername"]}",
			"password": "${var.deployInfo["arcgisAdminPassword"]}"
	PROTECTED_SETTINGS
Configuration Management
As was touched on above, we are utilizing PowerShell DSC (Desired State Configuration) to handle the configuration of ArcGIS Enterprise as well as a few other tasks on the instance. To simplify things, I have included v2.1 of the ArcGIS module within the archive but the public repo can be found here. The ArcGIS module provides a means with which to interact with ArcGIS Enterprise in a controlled manner by provided various "resources" that perform specific tasks. One of the major benefits of PowerShell DSC is that it is idempotent. This means that we can continually run our configuration and nothing will be modified if the system matches our code. This provides administrators the ability to push changes and updates without altering existing resources as well as detecting configuration drift over time.
To highlight the use of one of these resources, let's take a quick look at the ArcGIS_Portal resource which is designed to  configure a new site without having to manually do so through the typical browser based workflow. In this deployment, our ArcGIS_Portal resource looks exactly like the below code. The resource specifies the parameters that we must be provided to successfully configure the portal site and will error out if all required parameters are not provided.
ArcGIS_Portal arcgisPortal {
    PortalEndPoint = (Get-FQDN $env:COMPUTERNAME)
    PortalContext = 'portal'
    ExternalDNSName = $externalDNS
    Ensure = 'Present'
    PortalAdministrator = $arcgisAdminCredential
    AdminEMail = 'example@esri.com'
    AdminSecurityQuestionIndex = '12'
    AdminSecurityAnswer = 'none'
    ContentDirectoryLocation = $portalContentLocation
    LicenseFilePath = (Join-Path $(Get-Location).Path (Get-FileNameFromUrl $portalLicenseUrl))
    DependsOn = $Depends
$Depends += '[ArcGIS_Portal]arcgisPortal'‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Because of the scope of what is being done within the configuration script here, we will not be doing a deep dive. This will come in a later article.
Putting it together
With the changes to the Terraform template as well as a very high level overview of PowerShell DSC and its purpose, we can deploy the environment using the same commands mentioned in the first entry in the series. Within the terminal of your choosing, navigate into the extracted archive that contains your licenses, template and DSC archive, and start by initializing Terraform with the following command.
terraform init
Next, you can run the following to start the deployment process. Keep in mind, we are not only deploying the infrastructure but configuring ArcGIS Enterprise so the time for completion will vary. When it completes, it will output the public facing url to access your ArcGIS Enterprise portal.
terraform apply
Summary
As you should quickly be able to see, removing the manual configuration aspects of software as well as the deployment of infrastructure, a large portion of problems can be mitigated by moving toward IaC and Configuration Management. There are many solutions out there to handle both aspects and these are just two options. Explore what works for you and start moving toward a more DevOps centric approach.
I hope you find this helpful, do not hesitate to post your questions here: Engineering ArcGIS Series: Tools of an Engineer
Note: The contents presented above are examples and should be reviewed and modified as needed for each specific environment.
more
3 0 6,164
RaymondBunn
Numerous technical sessions, spotlight talks, and conversations referenced the "Architecting the ArcGIS Platform: Best Practices" whitepaper (https://go.esri.com/bp). This document presents some implementation guidelines in the form of a conceptual reference architecture diagram and associated best practice briefs. You can use these guidelines to maximize the value of your ArcGIS implementation and meet your organizational goals.
more
4 0 828
MichaelGreen
There are many impactful change management components that can increase a technology solutions’ adoption rate among users.  People coming to UC get excited about so many new capacities or expanded utilization of their platform that will bring value to their organization.  Leverage these components to increase your success rate:
  • Preparing for Change is a strategic activity that should happen at the beginning of each project where you create strong alignment between people, the goals of the project, and the sponsors who will advocate for the technology’s use.
  • Managing Change is a series of initiatives that are integrated into your project plan to assist people in accepting and embracing the new capabilities or workflows of each project.
  • Reinforcing Change is the best practice to cement the new workflows into an everyday routine.  People interacting with technology brings your geospatial efforts to fruition.
Come by the Guiding Your Geospatial Journey area to talk with experts about people focused change management activities that can enhance and increase your technology adoption rates.  Additionally, here are several people-oriented sessions that are happening at UC:
Technical Workshops
Tuesday, July 9        Location: SDCC - Rooms
8:30 am
Helping the Workforce Survive and Thrive in Times of Technology Change
SDCC, Room 16 A
Wednesday, July 10        Location: SDCC - Rooms
8:30 am
Get the C-Suite’s Attention with Strategic Workforce Planning
SDCC, Room 31 A
1:00 pm
Increase GIS Adoption the Agile Way
SDCC, Ballroom 06 F
2:30 pm
Workforce Development Planning in Three Simple Steps
SDCC, Ballroom 06 F
4:00 pm
SDCC, Room 10
Spotlight Talks
Tuesday, July 9                             Location: SDCC – Expo: Guiding Your Geospatial Journey Spotlight Theater
10:30 am
Making It Real: Use Training to Make Your Tech Dreams Come True
Wednesday, July 10                          Location: SDCC – Expo: Guiding Your Geospatial Journey Spotlight Theater
4:00 pm
Focus on Training to Go the Distance
Expo Area
Stop by to connect 1-on-1 with Esri Staff and talk more about Change Management and Adoption Strategies in our Guiding Your Geospatial Journey area.
Tuesday, July 9                9:00 AM–6:00 PM
Wednesday, July 10        9:00 AM–6:00 PM
Thursday, July 11             8:00 AM–4:00 PM
more
2 0 798
by Anonymous User
Not applicable
Isn’t life all about people? People are responsible for successful or failed relationships, processes, plans, getting things done, and changing the trajectory of history. It’s no different in an organization – people are the critical piece of a well-executed geospatial strategy. So, if you focus on a strategy for educating, developing, growing, and nurturing those people in your organization, then it all flows from there.
My colleagues and I are excited to be at UC, sharing from our experience helping Esri users with their people strategy – we'd love to connect with you – you'll find us in all these places:
Technical Workshops
8:30 am
SDCC, Room 31 A
1:00 pm
SDCC, Ballroom 06 F
2:30 pm
SDCC, Ballroom 06 F
Spotlight Talks
Tuesday, July9                             Location: SDCC – Expo: Guiding Your Geospatial Journey Spotlight Theater
10:30 am
1:00 pm
Advance Your Goals with Esri Technical Certification
4:00 pm
Appointments
Tuesday, July 9 – Thursday, July 11 Location: SDCC – Expo: Guiding Your Geospatial Journey Spotlight Theater
Our training consultants will help you devise a strategy-driven learning plan that will ensure that your workforce has the skills to leverage ArcGIS. Leave with a high-level plan and strong justification to develop your workforce.
Schedule an appointment
Expo Area
Stop by to connect 1-on-1 with Esri Staff and talk more about People Strategy
Thursday, July 11             9:00 AM–4:00 PM
more
4 0 561
AdamCarnow
If you're headed to the 2019 Esri International User Conference and are interested in sessions for GIS Managers, here is a link to the GIS Manager Track:
https://userconference2019.schedule.esri.com/schedule?filters=1964269831
more
0 0 405
AdamCarnow
Are you a GIS manager, leader or other executive headed to the 2019 Esri International User Conference (UC)?  I know it can be a challenge creating your personal agenda for the world's largest GIS conference, so I created this flier to assist.  It covers suggested events and activities you should consider when deciding how to spend your valuable time at UC.  I hope you have a productive UC experience, and I hope to see you there!
UPDATED 6/24/2019 - Added GIS Manager Track and Get Advice from Esri Services section.
UPDATED 6/13/2019 - Corrected the name of the Implementing ArcGIS area in the Expo to “Guiding your Geospatial Journey”
FYI there are other Esri UC fliers here: https://community.esri.com/community/events/user-conference/content?filterID=contentstatus%5Bpublish...
more
3 0 2,058
by Anonymous User
Not applicable
It’s important for an organization to realize that creating a purposeful and actionable training plan that aligns its needs, goals, and objectives is highly critical.
A plan that is focused on the learning and development of the workforce can be the rudder that guides them toward success. Employees gain a sense of purpose with a better understanding of where they’ve been, where they are, and how far they must go to reach their goal. The organization benefits from a more productive, efficient, skilled, and empowered staff.
Failure to have a strategic training plan in place for your workforce can lead to unsuccessful projects and initiatives, and staff without a focus and vision for their role in the organization.
Esri Training Consultants partner with organizations of all sizes and industries to assess current skills and knowledge, while building awareness and making recommendations for key learning resources. There are hundreds of resources, ranging from instructor led training to self-paced e-Learning. Engage with an Esri Training Consultant right away!
The Strategic Impact of a Training Plan
Esri Spotlight Talk - UC 2018
more
3 0 593
DavidSchneider
New Contributor III
I had the honor of presenting the spotlight talk "Engage the Enterprise with GIS" at UC 2018.  The full capacity audience was fantastic, especially considering it was late in the day.   The talk was around the People side of the broader Enterprise GIS Strategy.  The broader strategy should include:
  • People
  • Process
  • Technology
  • Data
When engaging the enterprise, look at all the various business units and enlist the help of willing participants at various levels in the said business unit(s).   Then work with them to communicate in terms that are well understood and relevant to the intended audience.  Below is a graphic, extracted from Dr. Elliott Jacques' "In Praise of Hierarchy".  Note that the temporal and strategic levels are the parameters to use when communicating the value of utilizing GIS.
When using this model to engage with your audience, make sure you are addressing these core considerations from the audience perspective:
Why?
Why me?
Why Now?
The attached presentation provides more information about this concept.
As always, Esri is here to support you through your technology implementation and change.  Let us know if you have any questions.
more
2 0 568
AaronZureick
Thanks to everyone who joined the 'Value of Esri Technical Certification' spotlight talk.  With the growing global talent shortage, access to qualified individuals to strengthen your organization and serve your customers is paramount.
  • Leverage Esri Technical Certification to enhance your personal and organizational brand
  • Independent studies show the value that certification brings to performance, efficiencies and responsibilities
  • Stay current, stay connected and share your certification successes using Esri resources, groups and websites
more
3 0 689
PindeFu
My new book, Getting to Know Web GIS 3rd edition, has recently published.
In the book, I teach about Web GIS technologies as a holistic platform, and try to help you quickly become productive with Esri’s Web GIS platform. If you need a workbook to stay on top of the latest Web GIS technologies, this is for you.
 The book provides clear, step-by-step instructions on how to share resources to ArcGIS Online and ArcGIS Enterprise, create engaging 2D and 3D information products that work in web browsers and on mobile devices, design smart maps, and perform analysis online.
The first two editions made this book a bestseller and a preeminent book on Web GIS. The third edition builds on that success to match newer releases of ArcGIS Online and ArcGIS Enterprise, with the following updates:
  • A new chapter on image services and raster analysis
  • Separate chapters on mobile GIS and real-time GIS, with a more extensive experience on each
  • Tutorials migrated from ArcMap to ArcGIS Pro, the new and more powerful tool for processing and publishing GIS resources
  • A new 3D chapter showing how to create beautiful 3D scenes easily with only a browser.
  • New frontiers such as big data analysis, the Internet of Things (IoT), smart cities, virtual reality, augmented reality, and artificial intelligence.
  • New products such as ArcGIS Arcade, Survey123 for ArcGIS, Workforce for ArcGIS, Operations Dashboard for ArcGIS, ArcGIS GeoAnalytics Server, and ArcGIS Image Server
The book provides accompanying lab data and instructors PPT slides that can be downloaded at esri.com/gtkwebgis3. Both eBook and print versions are available through Amazon. https://www.amazon.com/Getting-Know-Web-GIS-Third .
I hope my book sparks your imagination and encourages creatives uses of Web GIS!
Here is the table of contents of the book.
more
4 0 895
105 Subscribers
