Thanks Jason Camerano, I will follow the process you outlined.
In cases where there isn't a connection line described (separate, distant portions that use a POB and tie point) would I just enter more origin to POB lines for the second or third parts after entering the traverse for the first part? Or should they be connection lines? I ask this because I'm not sure what process/fields/lines the LSA utilizes to adjust the fabric. Is there a diagram or something that shows the LSA adjustment process, what fields it uses to make adjustments?
Jeff
Jeff Ward
Summit County, Utah
