I have had problems with file geodatabases. Data will not display at certain scales, and I have layers set to be shown at all scales. This has been a problem with multiple file geodatbases, which does not happen in personal geodatbases. I also find it useful to work with data tables in Access, since Arcview/ArcCatalog are very restrictive in editing tables.
To: James Harrington <mickee320@yahoo.com>
Sent: Saturday, May 2, 2015 12:53 AM
Subject: Re: - why can't I create valid polygons
#yiv4778050979 * #yiv4778050979 a #yiv4778050979 body {font-family:Helvetica, Arial, sans-serif;}#yiv4778050979 #yiv4778050979 h1, #yiv4778050979 h2, #yiv4778050979 h3, #yiv4778050979 h4, #yiv4778050979 h5, #yiv4778050979 h6, #yiv4778050979 p, #yiv4778050979 hr {}#yiv4778050979 .yiv4778050979button td {}
reply from Rebecca Strauch in Mapping - View the full discussionJames, I didn't see what version you are running, but I wonder if you are hitting the limitation of the personal geodatabase (which is based on Access and does have limitations)? That might be why after three successful adds it has problems. I would recommend using a File geodatabase which is a much more robust format, and is supported moving forward. Five reasons why you should be using the File Geodatabase | ArcGIS Blog If you need help setting a file GDB up, this is the help from 10.2 ArcGIS Help (10.2, 10.2.1, and 10.2.2) it is similar in previous versions, but you can search in the help if this version doesn't work for you. I hope that helps.
Reply to this message by replying to this email, or go to the message on GeoNet |
Start a new discussion in Mapping by email or at GeoNet |
Following why can't I create valid polygons in these streams: Inbox |
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
