Hi i'm struggling to finalize a model i'm making. from my final results i want to extract the lowest (minimum) value and save it.
i'm using an "iterate feature classes" tool so i need to be able to add %name% into the expression so it will find the lowest value for each of the files that goes into the tool
The column Elev_Diff is the column i want the minimum value from
the name of the file will be a variable (from iterator) called %name%
any ideas?
