I'm having some problems with a model i'm attempting to make.
I have a folder of jpgs that i need to rotate.
I have also created a shp file that contains the jpg name / path and the angle to rotate by.
I'm hoping to use an iterator to select each row of the table, extract the file path / name and rotate the appropriate raster.
The tool i'm attempting to use is the rotate raster tool
Toolbox > Data Management Tools > Projections and transformations > raster > rotate
however i can't seem to get the rotate tool to accept the input raster (using get field value tool)
Is there any way i can make this work?
Using ArcView 10 sp5
