That's a great point, Ruchira Welikala. I had only tested this with a file geodatabase, but the issue you are describing is absolutely correct with SDE; you need to be the owner. Conveniently, I've also been working on an SDE maintenance script that will reconcile versions, compress, rebuild indexes, and analyze datasets (source inspiration). For those last two tools, you need to run them as the data owner. My solution (for SDE in Oracle 11g):
- Get all the distinct owner names from the domain objects
- For each owner, create a temporary sde connection file.
- Then use that temporary connection file to run whatever task you need (delete domain in this case).
Here is my final code that will remove unused domains from both local and remote (SDE) geodatabases. You will need to figure out a way to generate the password if it is different for each owner. Please test it out and let me know how it works for you.
import arcpy
from contextlib import contextmanager
import os
import shutil
import tempfile
def main():
try:
# Connection path to geodatabse (as administrator if SDE)
myGDB = r"C:\GISConnections\SDE@GTEST.sde"
# Get domains that are assigned to a field
domainsUsed_names = []
for dirpath, dirnames, filenames in arcpy.da.Walk(myGDB, datatype=["FeatureClass", "Table"]):
for filename in filenames:
print "Checking {}".format(os.path.join(dirpath, filename))
## Check for normal field domains
for field in arcpy.ListFields(os.path.join(dirpath, filename)):
if field.domain:
domainsUsed_names.append(field.domain)
## Check for domains used in a subtype field
subtypes = arcpy.da.ListSubtypes(os.path.join(dirpath, filename))
for stcode, stdict in subtypes.iteritems():
if stdict["SubtypeField"] != u'':
for field, fieldvals in stdict["FieldValues"].iteritems():
if not fieldvals[1] is None:
domainsUsed_names.append(fieldvals[1].name)
## end for subtypes
## end for filenames
## end for geodatabase Walk
# List of all existing domains (as domain objects)
domainsExisting = arcpy.da.ListDomains(myGDB)
# Find existing domain names that are not in use (using set difference)
domainsUnused_names = (
set([dom.name for dom in domainsExisting]) - set(domainsUsed_names)
# Get domain objects for unused domain names
domainsUnused = [
dom for dom in domainsExisting
if dom.name in domainsUnused_names
print "{} unused domains in {}".format(len(domainsUnused), myGDB)
# Cleanup
del domainsExisting
del domainsUnused_names
# Delete unused domains by owner
## For local geodatabses, owner is an empty string ('')
with makeTempDir() as temp_dir:
descGDB = arcpy.Describe(myGDB)
for owner in set([dom.owner for dom in domainsUnused]):
if descGDB.workspaceType == "RemoteDatabase":
## Use temporary SDE connection as owner
myGDB = arcpy.CreateDatabaseConnection_management(
temp_dir, ## out_folder_path
owner+".sde", ## out_name
"ORACLE", ## database_platform
"GISTEST.WORLD", ## instance
"DATABASE_AUTH", ## account_authentication
owner, ## username
"myuserpass", ## password
print arcpy.GetMessages()
## Format result object as string for path to connection file
myGDB = str(myGDB)
# Get unused domains for current owner
domainsUnused_currentOwner = [
dom.name for dom in domainsUnused
if dom.owner == owner
for domain in domainsUnused_currentOwner:
arcpy.DeleteDomain_management(myGDB, domain)
print "\t{} deleted".format(domain)
## end for domainsExisting_owners
## end with temp_dir
finally:
# Cleanup
arcpy.ClearWorkspaceCache_management()
@contextmanager
def makeTempDir():
"""Creates a temporary folder and returns the full path name.
Use in with statement to delete the folder and all contents on exit.
Requires contextlib contextmanager, shutil, and tempfile modules.
temp_dir = tempfile.mkdtemp()
try:
yield temp_dir
finally:
shutil.rmtree(temp_dir)
if __name__ == '__main__':
main()
