Loop through multiple folder and Calculate mean of raster of Same folder
3811
23
03-24-2017 12:18 PM
ShouvikJha
Occasional Contributor III
Hi All,
I am writing a script to loop through multiple folders and calculate mean of the raster of each folder's data sets and save it in same folder. Below script i am working, but its not producing the mean rasters for each year folder, after running the script its generating only name of "mean" raster in main folder, and overlapping it .
Below images showing the name of the raster in one folder, another folder the raster name is same, only year value is changed in different year.
here how to take the year value in name of mean raster (E.g. for 2001 folder, output mean raster name would be Mean_Temp_2001.tif, E.g. for 2002 folder, output mean raster name would be Mean_Temp_2002.tif)
Below i have attached data sets also (Test_data folder)v which i am working on.
Thanks.
import arcpy, os
from arcpy import env
arcpy.CheckOutExtension("Spatial")
arcpy.env.overwriteOutput = True
env.workspace = r"D:\Test"
outraster = env.workspace
walk = arcpy.da.Walk(env.workspace, topdown=True, datatype="RasterDataset")
for dirpath, dirnames, filenames in walk:
    print dirpath
    rasterList = []
    for file in filenames:
        raster = os.path.join(dirpath, file)
        rasterList.append(raster)
        rasMean = arcpy.sa.CellStatistics(rasterList,"MEAN")
        rasMean.save(os.path.join(outraster,"mean.tif"))
        print rasMean‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
XanderBakker
Esri Esteemed Contributor
Hi shouvik jha , try the script below (change the input path at line 7):
def main():
    import arcpy
    import os
    ws = r'C:\GeoNet\LMFCMSF\Test_Data'
    walk = arcpy.da.Walk(ws, topdown=True, datatype="RasterDataset")
        print "Processing folder:", dirpath
        rasters = []
        for filename in filenames:
            raster = os.path.join(dirpath, filename)
            if filename.upper().endswith('.TIF'):
                if filename.upper().startswith('MEAN') == False:
                    rasters.append(raster)
        print " - rasters found:", len(rasters)
        if len(rasters) != 0:
            print " - calculate mean..."
            file_name_only = os.path.splitext(rasters[0])[0]
            tifname = file_name_only[-4:]
            ras_mean = arcpy.sa.CellStatistics(rasters, "MEAN", "DATA")
            ras_mean_name = os.path.join(dirpath,'Mean_{0}.tif'.format(tifname))
            ras_mean.save(ras_mean_name)
            print " - save mean raster as:", ras_mean_name
        else:
            print " - skipping folder..."
    print "Finished..."
if __name__ == '__main__':
    main()
This will print the following text:
Processing folder: C:\GeoNet\LMFCMSF\Test_Data
 - rasters found: 0
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2001A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2001A\Mean_2001.tif
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2002A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2002A\Mean_2002.tif
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2003A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2003A\Mean_2003.tif
Processing folder: C:\GeoNet\LMFCMSF\Test_Data\2004A
 - rasters found: 12
 - calculate mean...
 - save mean raster as: C:\GeoNet\LMFCMSF\Test_Data\2004A\Mean_2004.tif
Finished...
The resulting rasters seem to be OK...
Kind regards, Xander
IanMurray
If you are running this as a standalone script, you will need to have arcpy check out a Spatial Analyst Extension.
ShouvikJha
i added the line,but its behave the same as earlier .
ShouvikJha
@lan , i heve updated  above code, but its producing only single output name "mean" and overlapping the output for multiple time in main folder, output not save in source of input raster folder
NeilAyres
Take this out of the loop.
print rasMean
Assemble the rasterList first, then calculate the mean
ShouvikJha
Thank you, May i get one example of this
DanPatterson_Retired
Neil is suggesting dedenting the last 3 lines so that cell statistics is performed on the whole list rather incrementally as your script is doing.  Note, all the folders must be within one folder or a subfolder within it
ShouvikJha
Hi, I have updated my script, Below script printing only folder name, its not calculating the mean of raster from different folder
Script:
import arcpy, os
    print dirpath
    rasterList = []
        rasterList = arcpy.ListRasters("TIF")
    for Rasters in rasterList:
        rasMean = arcpy.sa.CellStatistics(Rasters,"MEAN", "DATA")
        file_name_only = os.path.splitext(Rasters)[0]
        rasMean.save(os.path.join(outraster,'Mean_{0}.tif'.format(tifname)))
        print rasMean‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
After running the script, its printing folder only
D:\Test
D:\Test\2001
D:\Test\2002
D:\Test\2003
D:\Test\2004
D:\Test\2005
D:\Test\2006
D:\Test\2007
D:\Test\2008
D:\Test\2009‍‍‍‍‍‍‍‍‍‍
You do realize that rasmean is a raster and not a single number don't you?  And don't you want lines 16-21 indented one more level?
ShouvikJha
Patterson i have updated the line 16-19, still script behave the same
