Remove Layers
6574
16
04-12-2015 02:59 AM
Yaron_YosefCohen
Occasional Contributor II
Hi  everyone,
i have mxd with 85 layers and i try to remove layers (with arcpy) that don't exist in the current data frame. i using this code:
import arcpy,os,sys,string
import arcpy.mapping
from arcpy import env
env.workspace = r"C:\Project"
for mxdname in arcpy.ListFiles('*.mxd'):
     print mxdname
     mxd = arcpy.mapping.MapDocument(r"C:\Project\\" + mxdname)
     df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
     for lyr in arcpy.mapping.ListLayers(mxd,"",df):
          if lyr in df.extent == False:
               arcpy.mapping.RemoveLayer(df, lyr)
               print 'RemoveLayer'
     mxd.save()
del  mxd
but i get en error:
Project.mxd
  File "C:/yaron/shonot/software/gis/tools/YARON_SCRIPTS/aaaaaaaaaaaaaa.py", line 15, in <module>
TypeError: argument of type 'Extent' is not iterable
i don't know why my code doesn't work.
Thanks for any help.
Yaron_YosefCohen
you think maybe geonet help community would be more compatible to my question?
Luke_Pinner
MVP Regular Contributor
The 'overlaps' method must return False if the dataframe extent is completely within/completely contains the layer extent. Try the 'disjoint' method instead. See the documentation - http://resources.arcgis.com/en/help/main/10.2/index.html#//018z00000072000000
Something like:
        print mxdname
        mxd = arcpy.mapping.MapDocument(os.path.join(env.workspace, mxdname))
        for lyr in arcpy.mapping.ListLayers(mxd, "" ,df):
              if df.extent.disjoint(lyr.getExtent()):
                  print lyr
        mxd.save()
    del  mxd
Yaron_YosefCohen
thanks Luke !! it works!!
Yaron_YosefCohen
the code don't work with shape file - just with layer file
Luke_Pinner
Correct. A feature class does not have a "getExtent()" method like a layer does. You need the arcpy.Describe method and the extent property - i.e. arcpy.Describe(shapefile).extent
GeorgeReece_Jr_
New Contributor III
I think Luke has the correct answer to this problem.
