Hi everyone,
i have mxd with 85 layers and i try to remove layers (with arcpy) that don't exist in the current data frame. i using this code:
import arcpy,os,sys,string import arcpy.mapping from arcpy import env env.workspace = r"C:\Project" for mxdname in arcpy.ListFiles('*.mxd'): print mxdname mxd = arcpy.mapping.MapDocument(r"C:\Project\\" + mxdname) df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] for lyr in arcpy.mapping.ListLayers(mxd,"",df): if lyr in df.extent == False: arcpy.mapping.RemoveLayer(df, lyr) print 'RemoveLayer' mxd.save() del mxd
but i get en error:
>>> Project.mxd Traceback (most recent call last): File "C:/yaron/shonot/software/gis/tools/YARON_SCRIPTS/aaaaaaaaaaaaaa.py", line 15, in <module> if lyr in df.extent == False: TypeError: argument of type 'Extent' is not iterable >>>
i don't know why my code doesn't work.
Thanks for any help.
you think maybe geonet help community would be more compatible to my question?
Cross-posted arcpy - How to remove layers that are not in visible df extent - Geographic Information Systems Stac...
for completeness
The 'overlaps' method must return False if the dataframe extent is completely within/completely contains the layer extent. Try the 'disjoint' method instead. See the documentation - http://resources.arcgis.com/en/help/main/10.2/index.html#//018z00000072000000
Something like:
for mxdname in arcpy.ListFiles('*.mxd'): print mxdname mxd = arcpy.mapping.MapDocument(os.path.join(env.workspace, mxdname)) df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] for lyr in arcpy.mapping.ListLayers(mxd, "" ,df): if df.extent.disjoint(lyr.getExtent()): arcpy.mapping.RemoveLayer(df, lyr) print lyr mxd.save() del mxd
thanks Luke !! it works!!
the code don't work with shape file - just with layer file
Correct. A feature class does not have a "getExtent()" method like a layer does. You need the arcpy.Describe method and the extent property - i.e. arcpy.Describe(shapefile).extent
I think Luke has the correct answer to this problem.
