Well, the AG Pro "script" is:
arcpy.ia.ZonalStatisticsAsTable("U2_LPIS_m10_10rast1", "BLOCKID", "Focal Statistics_Extract Bands", r"D:\Projekt\SJV_Blockkontroll2022_XXXXXXX_MILE\Arbete\Produktion\U2\ZonalStatistics\U2_zonalstats.gdb\U2_LPIS_m10_10rast1_textur", "DATA", "MEAN", "CURRENT_SLICE", 90, "AUTO_DETECT")
That probably doesn't help you much.
The Python script (the last one of many, many that I've tried) is:
from arcpy import CheckInExtension, CheckOutExtension
from arcpy.ia import ExtractBand, FocalStatistics, NbrRectangle, ZonalStatisticsAsTable
from datetime import datetime as dt
from os import path
print("Starting at {0}".format(dt.now()))
CheckOutExtension("ImageAnalyst")
proj_mapp = path.join(r"D:\Projekt", "SJV_Blockkontroll2022_XXXXXXX_MILE")
arb_dir = path.join(proj_mapp, "Arbete")
prod_dir = path.join(arb_dir, "Produktion")
mos_dir = path.join(prod_dir, "U2", "Mosaik")
mos_gdb = path.join(mos_dir, "U2_mosaic.gdb")
in_md = path.join(mos_gdb, "NIR_red_green_mosaic")
red_band = ExtractBand(in_md, [1])
textur = FocalStatistics(red_band, NbrRectangle(3, 3, "CELL"), "RANGE")
m10 = path.join(arb_dir, "Indata", "U2", "LPIS", "U2_LPIS.gdb", "U2_LPIS_m10_del1")
print("Starting Zonal Stats at {0}".format(dt.now()))
ZonalStatisticsAsTable(m10, "BLOCKID", textur, path.join(prod_dir, "U2", "ZonalStatistics", "U2_zonalstats.gdb", "U2_LPIS_m10_10rast1_textur_python"), "DATA", "MEAN", "CURRENT_SLICE", 90, "AUTO_DETECT")
CheckInExtension("ImageAnalyst")
print("Finished at {0}".format(dt.now()))
Like I wrote, the script works without any errors and the process time up to running Zonal Statistics as Table can be counted in microseconds.
The reason for the excessive amount of path variables has to do with the main script, of which this little snippet is a part.
My problem is that it takes about 24 times as long to run it as a Python script than from within ArcGIS Pro.
