Attribute Assistant Examples
2223
01-15-2014 10:22 AM
BillTen_Broeck
I have had pretty good luck using the AA to automate some of our tasks. However, I am sure I'm using a small portion of the functionality that is available, simply because some of the methods are a black box to me. E.g., X_Coordinate. Reading through the documentation it says you need to provide the "feature location", but I have no idea what that means from the standpoint of what the function is looking for.
Is there any place that there is a set of examples that showcase how these functions are used?
MikeMillerGIS
Esri Frequent Contributor
Bill,
   The Address Editing Map and the Water Utility Editing Map both provide an example of how to use the Attribute Assistant.
BillTen_Broeck
Thank you Mike. We are using the Address Editing, but I hadn't looked at the Water Utility map yet. Thanks much for the info.
TimWitt
Bill,
I have written an article for the ArcUser magazine, maybe that can help you some?
Tim
