Executive Dashboard Set Up Problem
1975
09-25-2013 11:00 PM
MattSheehan
Occasional Contributor III
We are trying to configure the executive dashboard and have run into a snag. See the video below which walks through the issue:
http://webmapsolutions.com/question/execdashboardIssue/execdashboardIssue.html
We are running Apache locally for testing. Any insight would be a great help.
Thanks
--Matt
AllisonMuise
New Contributor III
Hi Matt,
What version of Executive Dashboard are you using?
I see that the webmaps are public (which is good). Are the services public as well?
-Allison
MattSheehan
Allison,
We are using 10.1 and all services are public.
Thx
--Matt
AllisonMuise
New Contributor III
Hi Matt,
Everything in your setup looks good. The only place where I'm seeing a potential cause for that error is with Apache. The proxy we provide is written for IIS using Microsoft ASP.NET Framework 4.0. The proxy is handling signing into the group, and running this proxy under Apache is not a tested configuration.
If IIS is not an option and someone in your organization has the skills, you could play around with using something like the mono project to run ASP.NET on your Apache server, but this may also require some re-writing of the proxy/application code and would take you well beyond supported configuration of the application.
Cheers,
Allison
