Last week I tried deploying the November 2020 first release of the Water Distribution Data Management for ArcGIS Online, and the Sewer Version as well. Quite a few issues:
Water
- Had to deploy the template several times, would fail part way through. Now I have multiple folders in ArcGIS Online that have some of the template install, but I also cant delete the folders either, as it says I cant delete them, despite nothing inside them having delete protection turned on.
- When deploying to solution, it prompts you to pick a spatial reference. I selected NAD 83 State Plane NY West Ft, and it appeared to accept my input, however, when I download a file geodatabase of the hosted feature layers the template creates, it is still in Web Mercator. So that part does not appear to work.
- When I download the ArcGIS Pro Project Package that gets installed, all of the layers in the map when it opens in ArcGIS pro have the red exclamation point next to them, and I have to manually reassign them to the hosted feature layers.
Sewer Template
- Same error as listed above for #1
- Same error as listed above for #2
- When I download the ArcGIS Pro Project Package that gets installed, it opens up in ArcGIS pro completely blank.
Overall this looks like a great start with the templates, so hopefully these issues above can get resolved.
Thanks
Dan
