Why does ArcGIS Pro (and map for that matter) take so long reading/accessing a file geodatabase...
574
06-26-2020 07:25 AM
KenBates1
New Contributor III
Doesn't matter how complex...one feature class or 50 ...takes minutes....like 15 to just see the features...adding the features takes as long...
Robert_LeClair
Esri Notable Contributor
Quite simply - it shouldn't.   My *.gdb response rates are very fast with local *.gdb's.  I wonder if your *.gdb is corrupt?  One way to test is create a new file geodatabase on disk, copy/paste some feature classes to the new *.gdb.  What is the response rate?  Also, are you accessing your *.gdb's on a network?
KenBates1
New Contributor III
Okay...thanks I think its the NAS ....I had read some issues with Pro...but I think i need to rebuild the NAS!
Thanks again!
Robert_LeClair
This is also a great diagnostic tool - ArcGIS Diagnostic Monitor - you can use in ArcGIS Pro to see what response times are with all kinds of inputs/outputs - click CTRL-ALT-M to open it.  You can read more about it here.
KenBates1
New Contributor III
wow... not a well known feature...but nice!...thanks
