How do we add time extent to a feature layer in the new Android SDK (100.0.0) ?
935
5
04-06-2017 04:23 AM
SushantGiri
I am creating a map application where I have a feature layer. The layer consists of fire events taking place in the country. In the previous SDK, Time Extent feature was included so that the fire events could be filtered but the new SDK release(100.0.0) does not have this class so, my concern is, how do I implement this feature??
CenterlineMapping
Hello Sushant,
We have not been able to find a Time Extent solution using the older 10.2.8 version of the Android SDK either.  There seems to be documentation although, we are unable to apply the time extent to the dynamic map service layer.  Keep us informed if you find a solution.
AlexanderNohe1
Hi Centerline Mapping‌,
For the older version of the runtime, have you tried using LayerTimeOptions | ArcGIS Android 10.2.9 API  ?
Alexander
CenterlineMapping
Hi Alexander,
Thanks for your response.  We were not aware of that class.  Is there more documentation other than the link above that show how to implement this for a dynamic map service layer such as radar on Android?  We are very interested to enable time on several map services.
AlexanderNohe1
This documentation is the only other thing that I found. Time-aware layers—ArcGIS Runtime SDK for Android | ArcGIS for Developers
Let me know if you need any other assistance.
Alexander
ShellyGill1
Maybe you already found this info, but you can find out how to serve time-aware services here:
Serving time-aware layers—Documentation | ArcGIS Enterprise
This links to the desktop information as well, on how to configure the time-aware data in ArcMap that you then use to publish your service. Once that's set up you can then look at the API in Android that Alexander pointed out.
