@CochranBob, we were able to find the issue. It appears that the logic for Cut changed at 2.9 and rather than returning an empty array when the feature was not cut, it is returning 1 feature, the original geometry. So it is a fairly easy fix, on line 61 rather than checking if their are 0 features in the array, check if there are less than 2 features. See the screenshot below.
