Conditional Statement
2274
16
07-04-2017 08:30 AM
johnmonks
New Contributor II
Hey, so, having frustraited over this for ages I give up and will ask
I have a conditional statement I applied to an NDVI layer to apply a double sided membership function to it
It is in 32 bit float as it is decimal. The following statement was used
Con((Float("spainndvi" < 0.13)) & (Float("spainndvi" > 0.9)), 0, Con((Float("spainndvi" >= 0.13)) & (Float("spainndvi" <= 0.32)), (Float("spainndvi" - 0.13)) / (0.32 - 0.13)), Con((Float("spainndvi" >= 0.6)) & (Float("spainndvi" <= 0.9)), (Float(0.9 - "spainndvi")) / (0.9 - 0.6), 1))
The odd thing is it worked when I last used it but having miss named the file I deleted it by accident, went to re-run the statement and it just gives me an error. Is there something obviously wrong with my statement? Thanks
DanPatterson_Retired
I worked with the generic form, it was getting too hard to follow, then I tried to back fill
Con((a < 0.13) & (a > 0.9), 0, then the rest.....
but it should have been
Con((a < 0.13) | (a > 0.9), 0, then the rest.....
johnmonks
New Contributor II
Hey forgive my lack of insight but say for NDVI I thought the statement Con((Float("spainndvi") < 0.13) & (Float("spainndvi") > 0.9), 0 would specify that any number that is lower than 0.13 and higher than 0.9 will be attributed a value of 0?
that would be 'or'  ... a number can't be both... as in 'and', I can't remember off hand, but I think it is vertical bar '|' for or (I would have to check it up for the spatial analyst
a = 0.5    # start with a value of 0.5
(a < 0.3) & (a > 0.9)
Out[2]: False
(a < 0.3) | (a > 0.9)
Out[3]: False
a = 0.1    # try a new one with the same conditions
Out[5]: False
Out[6]: True
a = 1.     # let's go to the other possible side
Out[8]: False
Out[9]: True
JayantaPoddar
MVP Esteemed Contributor
Hi John,
Could you try out the expression that I have mentioned in my above comment?
Think Location
johnmonks
New Contributor II
Dan - I tried them both and it was indeed only taking one of the elements which was > 0.9 and therefor low values were given a wrong suitability, so much appreciated
Jayanta - I went back and tried the expression and it worked just fine and gave me the result I wanted as well so it seems that both ways work fine but I'm surprised it worked without the float because originally it was producing an integer result
Either way it produced the NDVI layer that I wanted so big thank you to you both
johnmonks
New Contributor II
Interestingly though, in regards to the brackets
Con(Float("tmp" > 8.64), 0, Con((Float("tmp" <= 8.64)) & (Float("tmp" >= 4.31)), (Float(8.64 - "tmp")) / (8.64 - 4.31), 1))
produced the same result as
Con(("tmp" > 8.64), 0, Con(("tmp" <= 8.64) & ("tmp" >= 4.31), (8.64 - "tmp") / (4.33), 1))
even though the brackets in the first one seem wrong.
curtvprice
Hey John,
This statement doesn't have much effect:
Float("tmp" > 8.64)‍‍‍
because you are floating a boolean result, so you get 1.0 if true 0.0 if false. It is more efficient just leave it as boolean.
You only get integer out of a divide ("/") operation if both the inputs are integer (or boolean).
If you want to force a float raster out raster calculator, put a single Float() around the whole expression.
One more thing, you can avoid some code because of the "else" behavior of Con. If tmp has a value and is <= 8.64, this can be assumed to make it to the else expression.
These expressions are equivalent:
Con(("tmp" > 8.64), 0, Con(("tmp" >= 4.31), (8.64 - "tmp") / 4.33, 1))‍‍‍‍
# both the folowing approaches will force a float raster output:
Con(("tmp" > 8.64), 0.0, Con(("tmp" >= 4.31), (8.64 - "tmp") / 4.33, 1.0))‍‍‍‍
Float(Con(("tmp" > 8.64), 0, Con(("tmp" >= 4.31), (8.64 - "tmp") / 4.33, 1))‍‍‍‍)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
* small update. To avoid the error message: "the truth value of a raster is ambiguous" you need parentheses around the comparison expressions.
https://community.esri.com/message/14091?sr=search&searchId=966e684e-305f-4ee4-9ca7-99a811458cfa&sea...
