POST | Hi, I´m astonished that the ability to automatically convert CAD drawings to geodatabase in Pro 3.0. has been removed... by HJSchneidt New Contributor II 1 8 | 1 | 8 | 997 | |
POST | Hello All, PLEASE NEED HELP....Can anyone help me how to migrating Map Template from ArcGIS Pro (many shp/feature cla... by NabillahHjUnus New Contributor 1 0 | 1 | 0 | 353 | |
POST | I have prepared a dwg file with pre-defined layers.Then I use the "Export to CAD" tool to convert a shapefile to DWGS... by MatsHardy Occasional Contributor 0 0 | 0 | 0 | 411 | |
POST | I'm having trouble uploading CAD file on ArgGIS Pro. On contents, the file is divided by features into point, annotat... by save501trees New Contributor 0 1 | 0 | 1 | 609 | |
POST | Looking for the best way to export an AutoCAD map with 20+ layers into ArcGIS 10.7. by WilliamMcConihe New Contributor 0 1 | 0 | 1 | 830 | |
POST | Hello,I'm hoping you can help me, the problem I'm having is I cannot see any drawings/files within my BIM360 cloud st... by Aðalsteinn_MarÓlafsson New Contributor III 0 1 | 0 | 1 | 750 | |
POST | Hi All,Okay, so total newbie when it comes to working with .dwg files, but I am about to throw my computer out a wind... by LaurenConnor New Contributor II 0 18 | 0 | 18 | 3267 | |
POST | I am trying to convert Public Land Survey System (PLSS) township or section data (shapefile or file geodatabase featu... by BRHolmes New Contributor II 0 2 | 0 | 2 | 1965 | |
POST | Hi, AllI have a problem of using BIM file to Geodatabase. The problem is that after updating pro 2.6, BIM file to geo... by TaehyoLee New Contributor 0 2 | 0 | 2 | 993 | |
POST | Is it possible to view Navisworks .nwd data in Pro, and also publish to 3D scene in Portal? I've been able to export ... by JoshTownsend New Contributor II 0 1 | 0 | 1 | 3506 | |
POST | If I have a BIM model published in a scene at a URL like "http://mydomain.com/home/webscene/viewer.html?webscene=1234... by DennisWelu1 New Contributor II 0 1 | 0 | 1 | 575 | |
POST | Every so often I get asked by our CAD guy to export parcel owner labels in certain areas of the city in which we will... by Brian_Laws Occasional Contributor 0 4 | 0 | 4 | 1793 | |
POST | Is there a way to show multiple full BIM models in a webscene at the same time? If I upload two SLPK models in the sa... by BirkS Esri Contributor 0 1 | 0 | 1 | 586 | |
POST | I am trying to change the data source of a CAD layer in a Pro map using arcpy. Looking at the documentation on the ar... by TedChapin Occasional Contributor III 0 2 | 0 | 2 | 656 | |
POST | We have BIM data in bentley i model format (i.dgn). Need to use that data in GIS analysis, so tried to convert that d... by KSathish New Contributor II 0 4 | 0 | 4 | 880 |
