Delete Unused Domains
15277
30
06-08-2015 11:50 AM
BlakeTerhune
MVP Regular Contributor
I created this script to help with some geodatabase house cleaning tasks. Maybe someone else will find it useful or have an idea to improve it.
import arcpy
import os
# Set workspace
myGDB = r"C:\temp\working.gdb"
# Get domains that are assigned to a field
domains_used = []
for dirpath, dirnames, filenames in arcpy.da.Walk(myGDB, datatype=["FeatureClass", "Table"]):
    for filename in filenames:
        print "Checking {}".format(os.path.join(dirpath, filename))
        try:
            ## Check for normal field domains
            for field in arcpy.ListFields(os.path.join(dirpath, filename)):
                if field.domain:
                    domains_used.append(field.domain)
            ## Check for domains used in a subtype field
            subtypes = arcpy.da.ListSubtypes(os.path.join(dirpath, filename))
            for stcode, stdict in subtypes.iteritems():
                if stdict["SubtypeField"] != u'':
                    for field, fieldvals in stdict["FieldValues"].iteritems():
                        if not fieldvals[1] is None:
                            domains_used.append(fieldvals[1].name)
        except Exception, err:
            print "Error:", err
# Get domains that exist in the geodatabase
domains_existing = [dom.name for dom in arcpy.da.ListDomains(myGDB)]
# Find existing domains that are not assigned to a field
domains_unused = set(domains_existing) ^ set(domains_used)
print "{} unused domains in {}".format(len(domains_unused), myGDB)
for domain in domains_unused:
    arcpy.DeleteDomain_management(myGDB, domain)
    print "{} deleted".format(domain)
python snippets
AndresCastillo
I got it to work:
import arcpy
import os
#Slightly modified from Geonet thread by Blake Terhune titled 'Delete Unused Domains'
# Set workspace
arcpy.env.workspace = arcpy.GetParameterAsText(0)
domains_used = []
        try:
                if field.domain:
            print "Error:", err
print domains_unused
print (domains_unused)
arcpy.AddMessage(domains_unused)
BlakeTerhune
Fixed in less than an hour! Love how just posting a problem can sometimes lead you to finding the answer yourself.
AndresCastillo
Absolutely, me too!
Thank you for your awesome script!
JeremyLinley
New Contributor III
I cannot get this to work as a tool in a toolbox. I copied it exactly and it is giving me the error 'NameError: name 'myGDB' is not defined. I have set the tool parameters to Display Name: Workspace | Data Type: Workspace. What am I doing wrong? Below is my script:
import arcpy
import os
# Set workspace
domains_used = []
        try:
                if field.domain:
            print "Error:", err
1 of 1 people found this helpful
    Helpful Yes  NoLike  0Reply
    • Andres Castillo
      I got it to work:
      import arcpy
      import os
      # Set workspace
      domains_used = []
              try:
                      if field.domain:
                  print "Error:", err
    BlakeTerhune
    I'm not sure exactly what Andres Castillo‌ changed to get his working, but it looks like the myGDB variable is undefined. Try assigning it on line 6 of your script like
    myGDB = arcpy.GetParameterAsText(0)
    AndresCastillo
    Hi Jeremy,
    as far as I can remember, Blake Terhune is right about what I changed.
    Did this work for you?
    RhettZufelt
    MVP Frequent Contributor
    running this in 10.2.1 (the GitHub version) I noticed that it see's SDE rasters as FeatureClass which errors out trying to get domain info.
    I had to limit the da.walk with this to get past the raster dataset(s) issues.
    for dirpath, dirnames, filenames in arcpy.da.Walk(myGDB, datatype=["FeatureClass", "Table"], type=['Polygon', 'Polyline','Point']):
    R_
    MicahBabinski
    Occasional Contributor III
    Outstanding, Blake Terhune! I saw you had provided a good answer to a question I posted a few years back about unused domains that included a link to this script. I'm getting it set up to work in my environment now. Thanks!
    JanTeisinger
    New Contributor II
    I understand this is an older thread, but for those folks who would prefer to simply list unused domains without running arcpy, you can use the following SQL query that I have put together:
    WITH SUBDomainsAndFields
    as
    		SELECT distinct
    		  UPPER(PARSENAME(ClassDefs.Name,1)) AS "ClassName",
    		  fieldDef.value('FieldName[1]', 'nvarchar(max)') AS "FieldName",
    		  fieldDef.value('(../../SubtypeName)[1]', 'nvarchar(max)') AS "SubtypeName",
    		  fieldDef.value('DomainName[1]', 'nvarchar(max)') AS "DomainName"
    		FROM
    		  GDB_ITEMS AS ClassDefs
    		CROSS APPLY
    		   Definition.nodes('/*/Subtypes/Subtype/FieldInfos/SubtypeFieldInfo') AS FieldDefs(fieldDef)
    		union all
    		   SELECT
    		  fieldDef.value('Name[1]', 'nvarchar(max)') AS "FieldName",
    		  NULL AS "SubtypeName",
    		FROM
    		CROSS APPLY
    		  Definition.nodes('/*/GPFieldInfoExs/GPFieldInfoEx') AS FieldDefs(fieldDef)
      SELECT ITEMS.[Name]
      FROM [dbo].[GDB_ITEMS] as ITEMS
      INNER JOIN GDB_ITEMTYPES as ITEMTYPES
    	on ITEMS.Type = ITEMTYPES.UUID
      WHERE (ITEMTYPES.Name = 'Coded Value Domain' OR ITEMTYPES.Name = 'Range Domain')
      AND ITEMS.[Name] NOT IN (SELECT DomainName FROM SUBDomainsAndFields WHERE DomainName is not null and DomainName <>'')
    CFDune
    For people who did find this script and want an updated one for ArcGIS Pro and use it in a toolbox. I've made a few changes to @BlakeTerhune script:
    import arcpy
    import os
    # Set workspace
    domains_used = []
            arcpy.AddMessage("Checking {}".format(os.path.join(dirpath, filename)))
            try:
                    if field.domain:
                for stcode, stdict in subtypes.items():
                        for field, fieldvals in stdict["FieldValues"].items():
            except Exception as err:
                arcpy.AddMessage("Error:", err)
    arcpy.AddMessage("{} unused domains in {}".format(len(domains_unused), myGDB))
        arcpy.AddMessage("{} deleted".format(domain))
    Under tool properties you have to add a parameter to be used in the script:
