For people who did find this script and want an updated one for ArcGIS Pro and use it in a toolbox. I've made a few changes to @BlakeTerhune script:
import arcpy
import os
# Set workspace
myGDB = arcpy.GetParameterAsText(0)
# Get domains that are assigned to a field
domains_used = []
for dirpath, dirnames, filenames in arcpy.da.Walk(myGDB, datatype=["FeatureClass", "Table"]):
for filename in filenames:
arcpy.AddMessage("Checking {}".format(os.path.join(dirpath, filename)))
try:
## Check for normal field domains
for field in arcpy.ListFields(os.path.join(dirpath, filename)):
if field.domain:
domains_used.append(field.domain)
## Check for domains used in a subtype field
subtypes = arcpy.da.ListSubtypes(os.path.join(dirpath, filename))
for stcode, stdict in subtypes.items():
if stdict["SubtypeField"] != u'':
for field, fieldvals in stdict["FieldValues"].items():
if not fieldvals[1] is None:
domains_used.append(fieldvals[1].name)
except Exception as err:
arcpy.AddMessage("Error:", err)
# Get domains that exist in the geodatabase
domains_existing = [dom.name for dom in arcpy.da.ListDomains(myGDB)]
# Find existing domains that are not assigned to a field
domains_unused = set(domains_existing) ^ set(domains_used)
arcpy.AddMessage("{} unused domains in {}".format(len(domains_unused), myGDB))
for domain in domains_unused:
arcpy.DeleteDomain_management(myGDB, domain)
arcpy.AddMessage("{} deleted".format(domain))
Under tool properties you have to add a parameter to be used in the script:
