Esri Geoportal Server Questions
54
517.7K
331
POST | Hello, I am trying to add a field to a published feature within my organization's server. I am allowed to do a join a... by CambriaEwart New Contributor 0 3 | 0 | 3 | 98 | |
POST | This release marks a whopping 20 years since the first release of the standards-compliant, open-source metadata appli... by Marten Occasional Contributor 3 0 | 3 | 0 | 209 | |
POST | Bonjour,Je souhaite faire une migration des services (publiés sur un ArcGIS Server 10.9) vers un ArcGIS Server 11.1.... by sigssarcgis New Contributor 0 1 | 0 | 1 | 161 | |
POST | hello everyonewe have a problem about ArcGIS server 10.9, so the deal is: our server works fine with port 6080 when w... by Vakhtang_Zubiashvili Occasional Contributor III 0 3 | 0 | 3 | 310 | |
POST | We have geoportal (version 2.6.5) and harvester (version 2.6.5) running in apache server. For the project purpose we ... by ArunPremachandran New Contributor II 0 3 | 0 | 3 | 515 | |
POST | I am testing importing metadata from UNC location. I tried both UNC path name and mapped drive name. Neither worked. ... by YinShi New Contributor III 0 6 | 0 | 6 | 613 | |
POST | Hi ESRI community,I'm trying to locally host the Geoportal 2.6.5 as per the instructions given in the official github... by ArunPremachandran New Contributor II 0 7 | 0 | 7 | 981 | |
POST | I set up a simple UNC path broker on my local C drive. When I imported the metadata (in xml) from c:\temp\TestUNCMeta... by YinShi New Contributor III 0 2 | 0 | 2 | 512 | |
POST | Hi ESRI community,I'm facing an error while saving the custom metatdata created by me. I have posted the error screen... by ArunPremachandran New Contributor II 0 4 | 0 | 4 | 843 | |
POST | Trying to set up JDBC connector to our enterprise SDE with oracle backend. Would anyone know what I need to put down ... by YinShi New Contributor III 0 10 | 0 | 10 | 992 | |
POST | Hello everyone, When setting up Geoportal 2.6.5 with ElasticSearch 8.1.3 on a Windows 10 VM, I followed the installat... by YinShi New Contributor III 0 2 | 0 | 2 | 9997 | |
POST | Hi, I am using Elastic Search URL to get metadata from ESRI Geoportal.When I am Posting query in Geoportal it is ret... by MahenderSingh New Contributor II 0 3 | 0 | 3 | 517 | |
POST | What is the recommended version to install if we wanted to have a disconnected configuration behind the firewall (i.e... by YinShi New Contributor III 0 1 | 0 | 1 | 452 | |
POST | Dear all First of all, Merry Christmas to all of you. Hope you are well and safe these days.I have tried to access to... by Anonymous User Not applicable 0 0 | 0 | 0 | 439 | |
POST | We have a plan to use ArcGIS Pro2.5 and Esri geoportal 2.x. Previously, ArcGIS Desktop was supporting to connect ArcG... by kgauravm30 New Contributor 0 1 | 0 | 1 | 563 |
